interior trim colour choice
Posted: Sun Aug 09, 2015 11:00 am
by Jin
I'm about to re-trim the dash and door and rear side panels in foam backed vinyl but can't decide on the colour, don't want black or grey, have considered white cream tan and dark red, anyone got any ideas and pictures?
Re: interior trim colour choice
Posted: Sun Aug 09, 2015 12:09 pm
by benofbrum
My Excelsior is trimmed in a royal blue Alacantra to match the seats and paintwork. Being matt, it does not cause a problem with reflections
Posted: Sun Aug 09, 2015 2:47 pm
by streetsy
Treasurers car (Michael H)is white with a vivid red interior, red may also look good against the purply blue of your car.
Posted: Wed Aug 12, 2015 5:38 pm
by ACourtney
The best advice that I have received from a professional trimmer is to stick to no more than two colours for the trim, otherwise it gets too fussy.
That can be harder than it sounds as the carpet will account for one colour and often the seat another. One of the best finished cars that I have been involved with is Stephen Kennedy's Gold Convertible.
He chose two shades of grey for the interior with the darker one on top (less reflective), so a light grey carpet was chosen to match the lighter trim colour.
- Kennedy Interior.jpg (107.02 KiB) Viewed 61795 times
This was the first Midas Gold with the IVA compliant door frame and my new door cards. The one thing I hated from my Excelsior was my elbow banging on the door release, so I moved it up and forward to alongside the steering wheel, to right below the point where the little steel triangle shows above the door top. This point provides three locations to tack weld screws to to hold the door pull in place. I also upgraded the cheap looking Metro door pull for a Rover 200/400/600 plated door pull. The pull rod just needed to be extended with some welding rod.
Posted: Wed Aug 12, 2015 7:44 pm
by Jin
That looks great, very high quality.
I think I've settled on black and red which will be just 2 colours,
Are the rover 25 interior handles a direct swap for the rover metro / 100 units?
Thanks for the replies
Posted: Wed Aug 12, 2015 8:12 pm
by ACourtney
I think they were off the earlier (square back) Rover 200, but also found in the 400, 600 and 800 and yes they were basically a direct swap. The fitting for the rod end is identical, but the plastic moulding is designed to go on an edge. I designed the new door panels to be in two parts, with the door handle recessed into the bottom edge of the top section. It is a shame that you missed the open day as you could have seen Stephen's car for yourself.
Posted: Wed Aug 12, 2015 8:14 pm
by streetsy
My interior is black with red stitching and piping, I have aluminium clock surrounds and centre console to brighten it up, black and red are good choices though.
Posted: Thu Aug 13, 2015 10:20 am
by Jin
Excellent, that combo works for me, just waiting on some material samples to finalise the choice
its taken forever to get he door cards somewhere near right structurally and fit n finish but i got the basics of the drivers door sorted last night so things are moving on.
Alistair thanks for the info in the handles, ill try and hunt some out, i would have loved to go to the open day but sadly couldn’t walk or drive due to a knee infection, roll on next year....
