Ignition wiring
Midasmatt
Ignition wiring
Post by Midasmatt »
Recently got a project midas for myself and it arrived today in the back of a horse lorry :)
got the engine turning over on the starter but theres no spark to any of the plugs...
some of the wiring loom in the ignition area is getting very hot when trying to start it.. am i right in thinking this is a short circuit somewhere?
havent had the chance to lok properly yet as i was out in the garage till 5 mins ago and its now 22:40 here... gotta be up at 6 haha
WhEn In DoUbT gIvE iT a ClOuT!
If YoU dOnT hAvE a SpAnNeR, hIt It WiTh A hAmMeR!
Re: Ignition wiring
yes it could be a problem with wiring. First thing I would check is your earths are all working and connected properly.
Check through usual suspect of coil, points (if fitted) condenser, leads. Have a look at wiring and see if anyone has been using tape or solder. Examine fuse box for corrosion, Replace any dodgy looking fuses. Get the multimeter out and check wiring end to end.
Hope that helps.
D
Return to “Mk 2”
