Resetting the Odometer?
I'd like to finish the complete rebuild of my Midas by resetting the mileage to zero (just had yet another speedo fitted). Mine has a Mk2 dash, any idea if it's possible?
Re: Resetting the Odometer?
It's easy to do. Just get a small flat blade screwdriver such as an electricians 1 and then you simply slide it down the side of each roller and rotate them to 0. Not very technical but does the job
Thanks Wolfie, I'll have a poke.
.... and it works!
Thank you Wolfie.
Thank you Wolfie.
