MGF Pedal box
MGF Pedal box
Chatting to Rich the other day we spoke about the Metro Pedal box, as Rich is considering changing to the Hydraulic type (due to fitting an uprated verto flywheel).
I wondered if anyone knew if the MGF Pedalbox was the same as on the Metro A series pre cable clutch adjust type, like mine, which is hydraulic.
I'm guessing it must be same/similar, knowing how the parts bin at Rover operated, however without seeing one I am just guessing.
Difference is (or should be) top mounting plate and clevis pin eye on the top of pedal.
Re: MGF Pedal box
Hopefully I'll be able to have a poke around a colleagues MGF later this week.
Re: MGF Pedal box
I have a feeling from some pics I have had a look at that it might have some differences as brake has a lever which works over the the nearside via a control bar for the servo (like bigchief does with his toyota mini conversion)....however the clutch pedal might be what you need!
I hope that makes sense.
Return to “General Chat”
