The bumpers are almost finished. I say that, there's still a bit of sanding left to do prior to paint, but not much. The rear bumper cleaned up quite nicely and only needed the tiniest of skims of filler for the very occasional bit I had missed with the P40. Just 180 grit sanding & it should be ready for the next stage: fitting them to the car. I will need to make up some brackets first. I have taken advice and will not be filling the bumpers with foam.
The front bumper was a little more involved, mainly due to the large amount of sanding I had to do, but now I am just waiting for the final filler skim to dry before finishing it off prior to bracket fitting. I need access to a welder for this and that won't be for 4 weeks thanks to holidays!
I have also run out of fibreglass resin - I took the time to fill in the hole where the old remote style gear linkage sat. I stuffed the hole with various rags around a bottle then used a cardboard template (made from a Jaffa Cake box of course) which I covered with tape as a release agent, then laid the fibrgelass & resin over the top. It's not perfect, but it will do for now until I can finish it off. I made a start on covering the various holes in the bulkhead as well. There are so many of them (some of them terrifyingly bad) that I thought it'd be a good idea to blank off everything and start again from scratch. That will make it a lot tidier!
Rear bumper pretty much done
Front one in progress - final skim done but not sanded
Card in place ready for fibreglassing
