Spax rear coil over shock absorbers
Postby mfdriver » Thu Oct 09, 2014 3:22 pm
Just to say that SPAX do still supply G999 shocks, because they have just delivered a pair to me.
For those who may be interested!
Malcolm
mfdriver
Re: Spax rear coil over shock absorbers
Postby Jvr19630 » Thu Oct 09, 2014 4:34 pm
Can you put some pictures up and give me some dimensions ?
Cheers John
Jvr19630
Postby mfdriver » Fri Oct 10, 2014 1:48 pm
What sort of dimensions - what have got fitted to the rear at the moment?
Malcolm
mfdriver
Postby Jvr19630 » Fri Oct 10, 2014 5:13 pm
Hi Malcolm,
Mine has got Gaz offset coil overs for a mini, so i do not have any reference point to work from.
I am looking for an over all length, lenth of fitted spring,
Are the ones you have adjustable spring platforms or just fixed
Any help would be appreciated
Thanks John
Jvr19630
Postby mfdriver » Fri Oct 10, 2014 6:30 pm
Can't send photos as already fitted to car before you posted your message.
They are fixed spring platforms, the old springs were 12.5" long progressive rating but unknown loading!
I have gone for new 10.5" springs, 2.25" dia. and 110lbs loading. The 12.5 " springs needed compressing to get them out, so basic distance between spring platforms was about 12" on old ones, about 11.5" on new ones.
These have lowered the rear by 2", but I have yet to try handling as front end currently up in the air awaiting fitment of Hi-Los and nearly new adjustable Spax shockers purchased from eBay.
I understand from the forum that GAZ offset are not really appropriate for Midas use, as offset can cause spring to rub on bodywork?
Hope this helps
Malcolm
mfdriver
Postby Jvr19630 » Fri Oct 10, 2014 6:57 pm
Thanks for the reply And information Malcolm.
I am taking the gaz shocks off as we know they are no good for the car
I can now decide what to use instead as plenty of information has been posted on this subject.
Thanks again John
Jvr19630
Postby Geoff Butcher » Sat Oct 11, 2014 8:32 pm
Jvr19630 wrote:Can you put some pictures up and give me some dimensions ?
Cheers John
The extended length of my Spax from the bolt centre to the top of the stem is 430mm. The fitted length of the original spring was 265mm and 285mm fully extended.
Postby Jvr19630 » Sun Oct 12, 2014 7:45 am
Thanks for the additional information Geoff.
I am going to lower mine so can now decide on sizes
Cheers John
Jvr19630
Postby goldeneye » Fri Jul 24, 2015 3:59 pm
mfdriver wrote:Can't send photos as already fitted to car before you posted your message.
Hope this helps
Malcolm
And, how does you car stand on it wheels now? Pictures please! :D
I want to lower my back of the car, and i am not sure what is the best buy for new springs and/or shocks.
I got the SPAG896-AS164 now fitted.
Midas Mk II
goldeneye
Postby mfdriver » Sun Jul 26, 2015 10:47 am
11" Coil Spring and 13" Revolution Wheels
13 inch wheels 1.jpg (124.13 KiB) Viewed 13210 times
Car is now for sale in For Sale page
This is how it sits
Malcolm
mfdriver
Return to Mk 2
