NEWBIE/AXLE
Re: NEWBIE/AXLE
Postby centredonkey » Tue Dec 13, 2016 4:05 pm
Aye, it is a little crispy!
Thanks for the drawings, Stuart.
centredonkey
Re: NEWBIE/AXLE
Postby centredonkey » Tue Jan 31, 2017 10:15 pm
Many thanks for the drawings, Stuart, here's a little "before and after" picture.
Think I'll spray the old one gold and in for the Turner Prize!
centredonkey
Re: NEWBIE/AXLE
Postby Stuart » Tue Jan 31, 2017 10:19 pm
Very impressive, that'll take a long time to rot.
Re: NEWBIE/AXLE
Postby centredonkey » Thu Feb 02, 2017 11:13 pm
Ooops, sorry for repeating myself, thought there was a tech problem with the site, turned out I'm so dim I didn't realise that there could be a page 2 on a thread!DOH!!!
Oh, and thanks to Steve for posting the pix of the beam, great to refer to when the drawings befuddled me.
centredonkey
Re: NEWBIE/AXLE
Postby miniswift » Thu Mar 30, 2017 9:39 pm
I have helped Alan makes his rear beam.
He has now 5 set of steels laser cutted so watch this space.
I made this for Geert
I have mine fitted to my Mini with my hand made rear radius arms.
Atchi
miniswift
Re: NEWBIE/AXLE
Postby centredonkey » Fri Apr 28, 2017 8:33 am
Our car now rolling again with all four wheels pointing in the right direction for the first time since we bought it!
Alas, now that the axle is sorted, the standard factory fitted Spax coilovers are making the arse end sit up even higher!
As they are banjaxed, I'm looking for a pair of bolt on replacements which will lower the rear at the same time
Any one found a good product that is currently available?
centredonkey
Re: NEWBIE/AXLE
Postby Stuart » Fri Apr 28, 2017 9:38 am
In my opinion the standard Gaz damper supplied for a Midas is 2" too long when fitted to a mk2.
They'll all make a damper to the length you ask for.
Dave at Dampertech supplied these AVO dampers for me when he used to sell AVO dampers, he also supplied the GAZ damper which works fine on a Midas Mk3.
This is that Midas Gaz damper fitted on full bump without a spring.
Re: NEWBIE/AXLE
Postby centredonkey » Fri Apr 28, 2017 1:46 pm
That looks more like it, Stuart.
What is the spec/spring length I need to ask Dave for?
centredonkey
Re: NEWBIE/AXLE
Postby Stuart » Fri Apr 28, 2017 2:31 pm
centredonkey wrote:That looks more like it, Stuart.
I can't remember the length exactly, I guess you could just ask Dave for a Midas one but 2" shorter, or erring on a less extreme one perhaps an inch shorter, then you can add a 4lb/inch run flat so that if you go for a racy rate of 110lb/in your dampers won't be at full extension.
You can see a compressed run flat spring on Jon's car
viewtopic.php?f=53&t=2752
here's mine on those AVO dampers
Picture 047.jpg (1.57 MiB) Viewed 25510 times
Re: NEWBIE/AXLE
Postby centredonkey » Mon May 01, 2017 8:58 pm
Thanks, Stuart, I'll contact Dave in the next few days.
Been busy dropping front subframe out...........at least what's left of it!!
centredonkey
Users browsing this forum: No registered users and 19 guests
