Chatting to Rich the other day we spoke about the Metro Pedal box, as Rich is considering changing to the Hydraulic type (due to fitting an uprated verto flywheel).
I wondered if anyone knew if the MGF Pedalbox was the same as on the Metro A series pre cable clutch adjust type, like mine, which is hydraulic.
I'm guessing it must be same/similar, knowing how the parts bin at Rover operated, however without seeing one I am just guessing.
Difference is (or should be) top mounting plate and clevis pin eye on the top of pedal.
