MGF Pedal box
MGF Pedal box
Postby manifold » Mon Sep 28, 2009 2:35 pm
Chatting to Rich the other day we spoke about the Metro Pedal box, as Rich is considering changing to the Hydraulic type (due to fitting an uprated verto flywheel).
I wondered if anyone knew if the MGF Pedalbox was the same as on the Metro A series pre cable clutch adjust type, like mine, which is hydraulic.
I'm guessing it must be same/similar, knowing how the parts bin at Rover operated, however without seeing one I am just guessing.
Difference is (or should be) top mounting plate and clevis pin eye on the top of pedal.
Re: MGF Pedal box
Postby Rich » Tue Oct 06, 2009 8:40 pm
Hopefully I'll be able to have a poke around a colleagues MGF later this week.
Re: MGF Pedal box
Postby manifold » Tue Oct 06, 2009 9:00 pm
I have a feeling from some pics I have had a look at that it might have some differences as brake has a lever which works over the the nearside via a control bar for the servo (like bigchief does with his toyota mini conversion)....however the clutch pedal might be what you need!
I hope that makes sense.
Return to General Chat
