Radiator for a Mk 3 (convertible)
lankyjames
Re: Radiator for a Mk 3 (convertible)
Post by lankyjames »
Hans Efde wrote:This one will fit:
http://www.ebay.co.uk/itm/PCC000104EVA- ... 2a1991dc5d
It will save you one rubber bend because usually the RH upper outlet faces outwards and the hose has to make a 180degree turn. This one is pointing aft which is beneficial. Just make sure it is a cross flow radiator, i.e. inlet and outlet at different sides. The first Metro radiator had inlet and outlet on the same side and this compromises the efficiency
I think this is what I have, both inlet and outlet are passenger side and side-ways facing, would I see much increase in efficiency with a cross-flow rad? What rubber pipework are people using from? A metro?
Just came back from work and checked my rad. You were completely right, mine is about 50cm's as well. sorry for the confusion. I checked the receipts I got with my car. The previous owner purchased his Metro radiator p/n 730119 from Andrew Page ltd in Leeds for the sum of 35.45 pounds in november 2000. Maybe they can still supply these.
Post by Alan D. »
You have probable got an Allegro radiator, which I imagine is very rare in itself!
max midas
Post by max midas »
@ Hans.
Thanks, I'll try them,though it may not be £35 nowadays ;)
Return to “Wanted”
