My usual motor factors either can't supply, or seem hideously expensive (maybe I'm just a cheapskate
Does anyone know of a source of rads for a Mk. 3 ie a metro radiator with kerbside outlet facing backwards and offside inlet facing outwards?
max midas wrote:I looked at all of them, they either have both inlet and outlet facing toward the rear of the car, or are marked 1990 onwards, ie a Rover Metro. Do these fit?
I am quite sure my radiator is bigger than 550mm. I'll check tomorrow.max midas wrote: The picture shows the mounting lugs at the edges of the radiator which is advertised as being 30inches (760mm) wide, my current radiator has mounting lugs 550mm apart, so I can't see it fitting the mounts.
