Does this look knackered to you?
Post by Jin »
K series left hand engine mount looking from the wheel arch, i have no point of reference but it don't look too clever
Re: Does this look knackered to you?
Post by Rich »
Just looked at the one on the GTM, the alloy section in the middle should be centralised between the rubbers, so no, yours doesn't look too clever.
Post by Jin »
Arse :(
Thanks mate
Much appreciated ;)
Post by b1zbaz »
That's fooked
Post by Jin »
Does explain 1 of the many clonking noises I hear on a daily basis
Anyone got a spare in any condition?
Worse case scenario I can use it as a pattern
Post by Jin »
New mounts are rather rare and over a hundred quid !!!!
So until i get round to fabricating a new one I've bodged it by jacking it up and trashing a piece of hard 8mm thick rubber that's super glued to a piece of 3mm ally filed to a taper into the void, hopefully it will hold out.
Actually on some forums I've read regarding this recently this would be considered an upgrade? :D
Post by Rich »
http://www.ebay.co.uk/itm/ROVER-METRO-3 ... 27d5d17b1c
That should be the one, I've used this supplier before and they are good, but call them first and just confirm it's the upper mount.
Post by Jin »
Nice one, cheers, I'll see what they say
Return to “Technical and Problems”
