Does this look knackered to you?
K series left hand engine mount looking from the wheel arch, i have no point of reference but it don't look too clever
Re: Does this look knackered to you?
Just looked at the one on the GTM, the alloy section in the middle should be centralised between the rubbers, so no, yours doesn't look too clever.
Arse
Thanks mate
Much appreciated
Thanks mate
Much appreciated
That's fooked
Does explain 1 of the many clonking noises I hear on a daily basis
Anyone got a spare in any condition?
Worse case scenario I can use it as a pattern
New mounts are rather rare and over a hundred quid !!!!
So until i get round to fabricating a new one I've bodged it by jacking it up and trashing a piece of hard 8mm thick rubber that's super glued to a piece of 3mm ally filed to a taper into the void, hopefully it will hold out.
Actually on some forums I've read regarding this recently this would be considered an upgrade?
http://www.ebay.co.uk/itm/ROVER-METRO-3 ... 27d5d17b1c
That should be the one, I've used this supplier before and they are good, but call them first and just confirm it's the upper mount.
Nice one, cheers, I'll see what they say
