Battery drain
Battery drain
Post by axshack »
Hi all,
my car has just totally drained a brand new battery in 3 days!! shock-horror!
so, I recharged it, hoping it was going to take a charge...but it seems to have done so ok...good...
I reconnected the positive cable, then used an Ammeter between the negative terminal and the negative cable....and got a reading of....5.6Amps !
Yikes! no wonder my battery died. This is a huge power drain on a car that is switched off I think you would agree, so now to identify what is causing the problem. So I am going to pull the fuses one-by-one to identify which circuit is at fault...BUT...I cannot locate a layout of the fuse and relay panel that makes sense.
I assume I have an '84 MG Metro donor, but does anyone have a sketch or know where I can locate a diagram to identify the fuses?
Dave :shock:
All That Glisters
Re: Battery drain
Post by All That Glisters »
Hi Dave
When I looked at my 89 Gold Coupe fuses this was the layout, I don't know if yours is different (what year was your car hatched?).
The wiring loom in original Midas (Corby) cars was a Midas special, it was not from the donor vehicle.
Hope it helps
Regards Mark
Gold Coupe Relays And Fuse Wiring 1989.jpg (824.76 KiB) Viewed 5645 times
Gold Coupe Fuse Layout 1989.jpg (731.9 KiB) Viewed 5645 times
Re: Battery drain
Post by axshack »
thanks for that very useful I think. my car was hatched in 88. :)
Return to “Mk 3 Coupe”
