AVONBAR
Re: AVONBAR
Post by Jin »
Your quite right, I've seen your setup and if I was going down the welded route I would choose this ideal.
My concerns regarding welded conversions centre around the Watson's setups and some home brewed concoctions I've seen on the mini forum.
This is the kind of thing I'm referring to not your well executed installation.
Here's a shot of a home made rear setup
The spring plate has no reinforcements (just flat) and is only welded top and bottom, not only that but considerable amounts of the subframe and side plate have been cut away to aid access to the spring in situ. Considering it could have upwards of 4-5000lb/in acting upon it I'd rather not.
Not only that but I really do want bolt in.
Re: AVONBAR
Post by Jin »
manifold wrote:I drove mine with Watson springs and top hats for 7 years as a daily driver. Often loaded up with stuff in the back and used a trailer too. Top hats were welded on with an arc welder. Might be agricultural but never had a problem with this conversion whatsoever. You do know the top hats have an inner retainer ring to stop the top of the spring wandering?
Were your Watson's springs on the rear?
Got any pictures?
Cheers and
Re: AVONBAR
Jin wrote: Were your Watson's springs on the rear?
Got any pictures?
Yours will be the first mk4 (to my knowledge) converted in such a way. David's is a mk3 so has coilovers.
Re: AVONBAR
Post by Jin »
Got any pictures?
ahh gotcha
shame they dropped that on the mk4 rear as it would have been a piece of cake by comparrison to fit a TF subframe to the front that come with coilovers fitted as standard and running a much more respectable 2:1 ratio as opposed to 3:1
oh well, gives me somthing to do....
Re: AVONBAR
Talking of TF frames here's a nice Honda engine with 310 hp.
k-series honda in tf frame.jpg (463.55 KiB) Viewed 24398 times
Re: AVONBAR
Post by Jin »
Tasty :)
Re: AVONBAR
Post by axshack »
As I caused this thread to get off topic a bit - but nevertheless very useful information - I thought I would bring it back with photos of my now completed AVONBAR engine....very shiny and looking forward to plugging it into the car ASAP !
once again the pic is flipped !!
Re: AVONBAR
Post by Jin »
Ooooooh
Shiny bits.
I love shiny bits
Re: AVONBAR
Post by axshack »
Jin wrote:Ooooooh
Shiny bits.
I love shiny bits
me too, and right now it is shiny inside as well as out !!
:D
Re: AVONBAR
Post by Jin »
Is that all dynoed up and ready to go?
Looks awesome
Return to “A series engined projects”
