pedalbox
pedalbox
Can someone inform me if the pedalbox used in the MKII is an original Mini classic pedalbox .
The reason of my question is that I intend to install a assembled pedalbox mini classic with cylinders, biasregulation , etc.....
On the other hand, I do not want to cut in the polyester fibre ...just drilling some holes if necessary .
I just have taken a random example of such a box .
Thanks
Thanks
- pedalbox OBP
- OBP0007PRTC-500x500.jpg (31.38 KiB) Viewed 12695 times
Re: pedalbox
Yes, the MKII has a mini classic pedalbox.
The mini pedal box came in two types, the late and early. My MKII has the early type.
Midas Mk II
Re: pedalbox
Hi thanks for the reply!
How can I see the difference between an early and late type ?
Or ...... will even the early and late type fit on the MKII ?
Re: pedalbox
Both types will have been fitted depending on the donor car, earlier ones had slimmer levers and smaller pads compared with later ones.ilmung wrote:Hi thanks for the reply!
The length and angle of the standard levers isn't correct for a Midas so some will have been modified, although the standard arms do fit and work I think. There are minor issues with the fixings too I think due to the GRP thickness. But then I'd imagine the pedal box you have in mind won't be a simple bolt in job even on a Mini.
Re: pedalbox
What year did the pedals changeStuart wrote:Both types will have been fitted depending on the donor car, earlier ones had slimmer levers and smaller pads compared with later ones.ilmung wrote:Hi thanks for the reply!
For my MK2, the pedals were out of a 1976 1275 GT, I didn't modify them as they felt pretty comfortable as they were, but to regain the full travel of the master cylinders before the pedal touched the floor I made longer push rods for both the master cylinders.
74 by Roy Forrester, on FlickrThe original length is the bottom one.
Re: pedalbox
I like thatfozzza wrote:
What year did the pedals change.
The change occurred in 1976 when the MK 4 was introduced.
Re: pedalbox
Yes Stuart I do work in a machine shop. When I built my Midas in 1989, I modified the existing push rods to extend them which worked ok but they were a bit of a bodge, so this time round with the new master cylinders I decided to make the push rods from scratch.
Re: pedalbox
I'll just get my list.fozzza wrote:Yes Stuart I do work in a machine shop.
Re: pedalbox
Is it as long as a toilet roll.
Joking aside, I wouldn't mind helping members out when ever possible, just send me a pm.
