nipples and stuff
nipples and stuff
Post by Jin »
hi all
what size fitting is it required to fit the rear grease nipples?
also, since the mk3 etc do away with rear hydragas so presumably the retaining straps , how do they overcome the tendancy for the frame to droop in use unsupported?
can the rear subframe bush be replaced with a bolted matalastic item?
cheers
Re: nipples and stuff
My MK3 used the top damper bushes and the standard metro metal tab ground off the top surface of the subframe, and a hole for the bolt to pass through. I have a vague recollection Alistair posted a photo of the set-up at some point.
ETA discussed here http://midasownersclub.co.uk/forums/vie ... =54&t=2640
Post by Alan D. »
Hi Jin,
If you read this article in the club magazine, you will see how I did mine.
file:///C:/Users/user/AppData/Local/Microsoft/Windows/INetCache/IE/CRZN70ZG/mcf01magazine.pdf
Post by Jin »
Nice one chaps.
Thanks loads
