ilmung
Post by ilmung »
Hi Stuart , thanks for the info !
micra midas l.jpg (92.71 KiB) Viewed 23786 times
ilmung
Post by ilmung »
On different places I find a name ( I suppose ) of a person who has done the body grp , someone knew him ?
IMG_0187 (Small).JPG (82.36 KiB) Viewed 23741 times
The name on the panels is the surname of the original owner who ordered the car.
ilmung
Post by ilmung »
What would you recommend for the rearmounts of the front frame ,solid or PU rubbers?
As I'll use PU rubbers between the frame and the bulkhead ,I suppose the rearmounts should be better with solid mounts , do you agree ?
ilmung wrote:Hi Stuart , thanks for the info !
The advice is usually all of the same type, so all original rubber, or all solid mounts. so if the top mounts are rubber that bit can move and flex, but the lower mounts are solid so the rear subframe legs will be flexing a little bit.
ilmung
Post by ilmung »
I am afraid to worn out the towerholes with the solid mounts .......
I think I will go hardrubber mounted everywhere ?
ilmung wrote:I am afraid to worn out the towerholes with the solid mounts .......
I think that because the rubber mounts allow movement that allows the the rubber to abraid/rub away the GRP, so a solid mounted subframe isn't going to do that because there will be no movement.
I only ever had standard rubber mounts on my cars so can't comment on whether there is an increase in noise and vibration.
ilmung
Post by ilmung »
I undestand what you mean .
But the body is polyester and you can turn the towerbolts with the correct torque and for sure it will be solid ....but for how long ....and when there 's any movemen than the soild rings will hit the grp and the worning of the holes will go very quick , I think .
I have put the frame ,just as test , once with solid mounts ....... the towerbolts with the right torque but without any front and rear mounts .....and the frame moves very easy ( like a clock pendulum) and I think that's normal because the contact frame /body is very little .
So I think that the front and rear mounts and very important and really hold the subframe in place and they should be solid mounted ,to avoid every movement , I would say the towermounts support mostly the body and have very few input in the stability of the frame ..........but I am not sure :?:
ilmung
Post by ilmung »
Today I have put some layers more for making the sandwish floor .
Feels much stronger than the original floor !
Next days I renforce the front and rear bulkhead , pictures follow !
IMG_0286 (Small).JPG (70.79 KiB) Viewed 23702 times
IMG_0243 (Small).jpg (68.63 KiB) Viewed 23702 times
IMG_0287 (Small).JPG (76.41 KiB) Viewed 23702 times
