Just thinking where to mount it as I didn't fancy anymore holes in the bodywork for the aerial also I've heard it has to be artificially grounded as well .Idears or photos welcome cheers
CB Radio
johnnyfixit
- Contact:
CB Radio
Anybody on here have a CB fitted to their Midas as I was thinking of fitting one to wor lasses car for future breakdowns
Re: CB Radio
Your best bet would be a marine aerial that doesn't require a ground-plane.
This is one example http://www.rocketradio.co.uk/solarcon-g ... 1358-p.asp
although there are neater ones out there.
johnnyfixit
- Contact:
kippy
Re: CB Radio
hi i've seen one fitted to a rear window ,I think the rear wiper was removed and he used the existing hole , don't know how well it worked . but it did look out of placed .
Re: CB Radio
johnnyfixit wrote:Yes but any good as a cb is only as good as the arieal used
As I said it will be the best you can do, just the same as an aerial on your house, so yes they're good.
Having said that a mobile phone is going to be cheaper and far more versatile.
johnnyfixit
- Contact:
Re: CB Radio
Stuart wrote:johnnyfixit wrote:Yes but any good as a cb is only as good as the arieal used
if your not in a convoy
