Alan D. wrote:
Yep, those ones.....
Any plans for more Alan?
Hi Rich,Rich wrote:If you'd be willing to share the dimensions I'd have a look, though I feel the cutting required would be fairly torturous on my relatively small Myford.
Somebody drilled and tapped the stub axle on Metro power,then made an extension of the stub axle which screwed in, after seeing a picture of our version of the stub axle, but I don't how successful or safe it was! You might find by doing a search on MP.manifold wrote:One mod you could do to make it easier to machine (one less thread to make on the bar) would be to drill out the shocker end and tap it 1/2" UNF (or equivalent metric) instead. Then fit shocker on a 1/2" caphead screw. Makes taking the shocker off easier as it doesnt need pushing out of way.
