Number plate lamps
Re: Number plate lamps
Post by DavidL »
manifold wrote:I believe they are from an allegro.
I have 'uprated' mine to fiesta mk3 ones which are better made.
Would that be this one, David?
http://www.ebay.co.uk/itm/ESCORT-FIESTA ... 3a6c836dd2
Exactly the same as the ones I gave a link for, and those were a bit cheaper too ;)
Jon
Post by Jon »
I've used this one on both Gold and Bronze; it looks neat and works well. As one of David's bumpers started life on my car it's probably the type he's referring to as well.
It was standard across the Ford range at the time.
http://www.ebay.co.uk/itm/Ford-Escort-M ... 564302611c
http://www.ebay.co.uk/itm/FORD-SIERRA-N ... 5ae49b3a16
As Jon recommends those are another option, I took his advice many years ago and have one of those on my MK 2.
With regard to the MK 3 I had at first thought they'd be too large, but on having just compared the two they're only a fraction larger, you will need to enlarge the opening but at least you'll know they can be made to fit.
Yes. Mine are same as these:
As Jon said. I had these on the bumper Jon gave me, plus I had them on my original bumper too. Just slightly bigger than original hole and a lot better built. Less likely to fall apart like the Allegro ones do....and the bulb replacement facility is better made.
Post by b1zbaz »
i have used a mini 1 stolen off my dads minus
Return to “Mk 3 Coupe”
