Cutting rear subframe for undertray fitting
Apart from removing the hydrolastic spheres and side plates do I need to trim anything off the rest of the standard subframe in order to fit the rear undertray. Although I haven't got an undertray as yet I have got the tank and everything else off and I might as well run the cutter over it now rather than take it all apart again when I do get a tray.
Re: Cutting rear subframe for undertray fitting
I'm pretty sure you also need to cut off the most rearwards bottom bit too.
npp 009.jpg (65.06 KiB) Viewed 8787 times
I can't find a reference to it in the build manual, or any drawings.
It's in the coupe build manual, 11 inches back from the front bottom edge of the subframe.
Stuart wrote:It's in the coupe build manual, 11 inches back from the front bottom edge of the subframe.
Cool, I can cope with that. Thanks Stuart!
10 minutes with a plasma cutter later, there's no going back now.......
My version of the cut, get rid of the dead meat!!!
Picture 3.JPG (929.62 KiB) Viewed 8771 times
It's not far off that Alan, but I've retained the top edge and rear mounting point. To be any more radical would mean dropping the frame off the car and I'm really not in the mood to do that right now.
